Fiche technique du Panasonic HC-X2
Panasonic HC-X2
PANASONIC CAMÉSCOPE HC-X2E
3 heures et 50 minutes (en continu) min
Capteur
15 millions de pixels
Carte mémoire
(SD / SDHC / SDXC) UHS-I Class3
Catégorie
prosumer
Cible
1 ''
Compression
MPEG-4 HEVC
Date de commercialisation
Novembre 2022
Diamètre filetage
67 mm
Dimensions
173 x 195 x 344 mm
Divers
Batterie 5900 mAh.
Ecran taille / résolution
3,5 '' - 2 760 K px
Enreg. audio manuel
Oui
Enregistrement
[4:2:0 10bit] UHD 3840x2160 59.94p/50.00p HEVC LongGOP 100M: approx. 100Mbps (VBR)
UHD3840x216029.97p/25.00p/23.98pHEVC LongGOP72M:approx.72Mbps(VBR)
[4:2:0 8bit] UHD 3840x2160 29.97p/25.00p/23.98p 420 LongGOP 72M: approx. 72Mbps (VBR)
FHD 1920x1080 59.94p/50.00p/23.98p 420 LongGOP 50M: approx. 50Mbps (VBR)
[4:2:0 10bit] UHD 3840x2160 59.94p/50.00p HEVC LongGOP 200M: approx. 200Mbps (VBR)
UHD 3840x2160 29.97p/25.00p/23.98p HEVC LongGOP 150M: approx. 150Mbps (VBR)
[4:2:0 8bit] UHD 3840x2160 59.94p/50.00p 420 LongGOP 150M: approx. 150Mbps (VBR)
UHD 3840x2160 29.97p/25.00p/23.98p 420 LongGOP 100M: approx. 100Mbps (VBR)
[4:2:2 10bit] UHD 3840x2160 29.97p/25.00p/23.98p 422 LongGOP 150M: approx. 150Mbps (VBR)
FHD 1920x1080 59.94p/50.00p 200M (ALL-Intra): approx. 200Mbps (VBR)
FHD 1920x1080 59.94i/50.00i 100M (ALL-Intra): approx. 100Mbps (VBR)
FHD 1920x1080 29.97p/25.00p/23.98p 100M (ALL-Intra): approx. 100Mbps (VBR)
FHD 1920x1080 59.94p/50.00p 422 LongGOP 100M: approx. 100Mbps (VBR)
FHD 1920x1080 59.94i/50.00i/29.97p/25.00p/23.98p 422 LongGOP 50M: approx. 50Mbps (VBR)
[4:2:08bit] PS1920x108059.94p/50.00p:approx.25Mbps(VBR) PH 1920x1080 59.94i/50.00i/23.98p: approx. 21Mbps (VBR)
HA 1920x1080 59.94i/50.00i: approx. 17Mbps (VBR)
PM 1280x720 59.94p/50.00p: approx. 8Mbps (VBR)
Entrée micro mini-jack
Entrées / Sorties diverses
Mini-jack télécommande 2,5 mm, prise LAN
Entrées XLR
oui (x2)
Equivalent 35mm en vidéo
24,5-490
Focales vidéo
8.8-176 mm
Griffe
Oui
Logiciel
HC ROP
Ouverture
f/2,8-f/4,5
Poids nu (ou complet)
2040 (2490) g
Prix fabricant
3199 (TTC) Euros
Résolution photo maxi
3840 x 2160 pixels
Résolution vidéo
UHD et HD
Sensibilité mode Nuit/Normal
0.6 lx (F2.8, Super Gain+, Obturateur 1/30 sec.) lux
Sortie casque
Oui
Sortie HD-SDI
Oui
Sortie micro-USB ou mini-USB
USB-C 3.1
Sortie Mini (micro) HDMI
HDMI
Stabilisateur
Hybride O.I.S (4K / FHD) 5 axes
Support
Carte mémoire / Carte mémoire
Torche
Viseur / Taille / Résolution
Viseur couleurs 0,39'' de 2,36 kp
Wi-Fi / NFC / GPS
Oui / - / -
Zoom optique
x20
Points forts
Zoom optique 20x (et même x24)
Capteur 1 pouce
Grand-angle 24,5 mm
Qualité image globale
Grand écran tactile de 3.5 pouces 2,760 Kp
3 bagues de réglages
Qualité stabilisation
Enregistrement 4:2:2 10 bits (30p/25p) et 4:2:0 8 bits (50/60p)
Vlog et HLG intégrés
Profils variés
3 filtres neutre (1/4, 1/16, 1/64)
14 boutons Fn
Chargeur externe
Ralenti VFR bonne qualité + Super Ralenti
iZoom 24x en UHD et 32x en FHD
Affichage combiné Viseur / écran
Nombreux paramétrages image
Enregistrement Double Codec (sous conditions)
XLR (x2)
Viseur de 2,36 Kp
Zébra
Points faibles
Le poids égal à 2,5 kilos, un peu lourd en 2023
Pas de 4K DCI
Points discutables
Les Menus, pas toujours très logiques
Absence de prise micro mini-jack
Pas d'histogramme
L'avis de Magazinevidéo
Le HC-X2 est une caméra étonnamment complète dans la gamme de prix très convoitée se situant autour de 3000 euros TTC. Elle apporte lun enregistrement jusqu’à 50p en UHD et un capteur moyen (1 pouce), un zoom X20, un grand-angle 24,5mm, des filtres ND intégrés,k du 4:2:2 (en 25/30p) et surtout, dispose de très nombreux réglages fins. Son Menu spécifique (SW Auto) gère les automatismes du mode Auto avec discernement. Son ergonomie est convaincante, les boutons sont bien agencés. On apprécie aussi le Wi-Fi désormais intégré (c'est un peu normal en 2023).
Alors parfaite la HC-X2 ? Pour dire non, il faut déjà chercher du côté du poids, assez conséquent pour un modèle « tout-terrain ». Oubliez peut-être l'idée d'emmener la HC-X12 en voyage ! Ensuite l'Autofocus n'est pas le point fort de Panasonic (mais les pros répondront qu'il suffit de basculer en Manuel).
J’ai également trouvé la qualité d’image du HC-X2 correcte tout en sachant qu'il reste difficile de concevoir un zoom optique 20x d’excellente qualité et de maintenir un prix raisonnable.
Bref, en termes de rapport qualité / prix, et compte tenu de ses nombreuses qualités, la HC-X2 a comblé une bonne parti!e des lacunes du HC-X1 et semble difficile à battre sur ce créneau "entrée de gamme pro". Pour alléger la facture de 700 euros, le HC-X20 est une bonne alternative si vous pouvez vous passer de nombreuses fonctions pros (V-log, HLG,connexion SDI-3G, Time-code et connexion LAN pour le streaming)
Pour être complet, signalons également que l'on peut encore se procurer le HC-X1 au prix de 2489 euros (sur le site Digit-Photo) , soit quasiment le prix du HC-X20.
Panasonic HC-X2 : les accessoires en option
LEXAR CARTE SDXC 128GB PROFESSIONAL UHS-II
LEXAR CARTE SDXC 64GB PROFESSIONAL UHS-II LEXAR CARTE SDXC 64GB PROFESSIONAL UHS-II (1667X)
PANASONIC BATTERIE AG-VBR59E
