Fiche technique du Sony Alpha 7R V
Sony Alpha 7R V
100 – 32 000 ISO (les valeurs ISO comprises entre 50 et 102 400 ISO peuvent être définies en tant que gamme ISO étendue), AUTO (100 – 12 800 ISO, limite inférieure et limite supérieure sélectionnables)
Vidéos :
Équivalent 100 – 32 000 ISO, AUTO (100 – 12 800 ISO, limite inférieure et limite supérieure sélectionnables)
7680 x 4320 (4:2:0, 10 bits, NTSC) (Environ) : 24p (400 Mbit/s / 200 Mbit/s)56, 7680 x 4320 (4:2:0, 10 bits, PAL) (Environ) : 25p (400 Mbit/s / 200 Mbit/s)
SYSTÈME D'ENREGISTREMENT DE VIDÉOS (XAVC HS 4K)
3840 x 2160 (4:2:0, 10 bits, NTSC) (Environ) : 60p (150 Mbit/s / 75 Mbit/s / 45 Mbit/s)5, 24p (100 Mbit/s / 50 Mbit/s / 30 Mbit/s)5, 3840 x 2160 (4:2:0, 10 bits, PAL) (Environ) : 50p (150 Mbit/s / 75 Mbit/s / 45 Mbit/s), 3840 x 2160 (4:2:2, 10 bits, NTSC) (Environ) : 60p (200 Mbit/s / 100 Mbit/s)857, 24p (100 Mbit/s / 50 Mbit/s)5, 3840 x 2160 (4:2:2, 10 bits, PAL) (Environ) : 50p (200 Mbit/s / 100 Mbit/s)
SYSTÈME D'ENREGISTREMENT DE VIDÉOS (XAVC S 4K)
3840 x 2160 (4:2:0, 8 bits, NTSC) (Environ) : 60p (150 Mbit/s)57, 30p (100 Mbit/s / 60 Mbit/s)5, 24p (100 Mbit/s / 60 Mbit/s)5, 3840 x 2160 (4:2:0, 8 bits, PAL) (Environ) : 50p (150 Mbit/s), 25p (100 Mbit/s / 60 Mbit/s), 3840 x 2160 (4:2:2, 10 bits, NTSC) (Environ) : 60p (200 Mbit/s)57, 30p (140 Mbit/s)5, 24p (100 Mbit/s)5, 3840 x 2160 (4:2:2, 10 bits, PAL) (Environ) : 50p (200 Mbit/s), 25p (140 Mbit/s)
SYSTÈME D'ENREGISTREMENT DE VIDÉOS (XAVC S HD)
1920 x 1080 (4:2:0, 8 bits, NTSC) (Environ) : 120p (100 Mbit/s / 60 Mbit/s)59, 60p (50 Mbit/s / 25 Mbit/s)5, 30p (50 Mbit/s / 16 Mbit/s)5, 24p (50 Mbit/s)5, 1920 x1080 (4:2:0, 8 bits, PAL) (Environ) : 100p (100 Mbit/s / 60 Mbit/s)9, 50p (50 Mbit/s / 25 Mbit/s), 25p (50 Mbit/s / 16 Mbit/s), 1920 x 1080 (4:2:2, 10 bits, NTSC) (Environ) : 60p (50 Mbit/s)5, 30p (50 Mbit/s)5, 24p (50 Mbit/s)5, 1920 x 1080 (4:2:2, 10 bits, PAL) (Environ) : 50p (50 Mbit/s), 25p (50 Mbit/s)
SYSTÈME D'ENREGISTREMENT DE VIDÉOS (XAVC S-I 4K)
3840 x 2160 (4:2:2, 10 bits, NTSC) (Environ) : 60p (600 Mbit/s)57, 30p (300 Mbit/s)5, 24p (240 Mbit/s)5, 3840 x 2160 (4:2:2, 10 bits, PAL) (Environ) : 50p (500 Mbit/s)7, 25p (250 Mbit/s)
SYSTÈME D'ENREGISTREMENT DE VIDÉOS (XAVC S-I HD)
1920 x 1080 (4:2:2, 10 bits, NTSC) (Environ) : 60p (222 Mbit/s)5, 30p (111 Mbit/s)5, 24p (89 Mbit/s)5, 1920 x 1080 (4:2:2, 10 bits, PAL) (Environ) : 50p (185 Mbit/s), 25p (93 Mbit/s)
8K, 4K
Vidéo 4K 30p suréchantillonnée depuis un flux 6,2 Mpx
Viseur de qualité remarquable (9,44 Mpx)
Stabilisation améliorée
Nouvel écran 3,2''
Sensibilité remarquable
plage dynamique de 15 IL en photo
14 diaphs en vidéo en s-log
Écran tactile
Pixel Shift (19008 x 12672 pixels)
Zone de détection AF à la couverture plus large (89%)
Mise au point autofocus améliorés
connexion câblée USB SuperSpeed 10 Gb
Autofocus précis et efficace, même en basse lumière
Picture Profile, S-Log2, S-log3 et S-Gamut
Peaking, histogramme
Double emplacement pour cartes
Sony Alpha 7R V : les accessoires en option
SANDISK CARTE SDXC EXTREME PRO UHS-II 256GB
SANDISK CARTE SDXC EXTREME PRO 128GB
